Possible starter issues...?
DaydreamDrifter
Car: 90 240sx 00 Altima
While doing a test run, something seemingly gave way and the car's revs went way down and died. Now car won't turn over but i beleive its the starter making a winding noise at high speeds. Could someone tell me what in the **** is going on with my peice of ****.
URM S14
Car: 95 240sx
sounds more like alternator...and starter. if your car doesnt start, try tapping the selenoid with a small pipe and have a friend try and turn it over. worked for me.-Chris
sdtouge
Car: 1990 240sx coupe
^what he said.
jump the battery and let it charge. let it run on its own, then remove the negative battery terminal connection, if it die, your in need of a new altenator.matt
Dattebayo
DaydreamDrfter wrote:Could someone tell me what in the **** is going on with my peice of ****.
Sounds like someone has an S13.
Your car is old enough now to need a alternator. I have a '93 and its just crapping out on me now. I call it luck.
If you replace it, do not get a advance auto or pep boys or auto zone alternator.
Only buy factory alternators from Nissan. The others will only last for about three months.
