streetspirit7 »
https://forums.nicoclub.com/streetspirit7-u14716.html
Fri Jul 01, 2005 3:11 pm
Ok, I set the timing on the engine according to the picture above, so it should be top dead center with the notches in the crank and the cam gear at 12 oclock, right? I reassembled the engine and put the crank pully on and the timing mark on it shows about 10 degrees BTDC. Did I do something wrong???
