Getting opinions and/or advice on whether it is possible to easily take my 4wd to a 2wd. The reason I want to commit this crime is as follows: My 4wd Pathy has a huge hole in the transfer case where the front shaft connects. Its ugly. How this happened really isn't important at this point and its something I don't want to relive anyway. I would say the hole is about the size of a gallon milk jug. I love the truck. Reality of it is.. 2003 with 300k miles +on it and while I wish i could just tow it down to MS Powertrain and have them fix it... that isnt an option for me financially. I've checked into getting a used transfer case and doing the replacement myself but after doing some reading I think this may exceed the limits of my Pathfinder Repair skill set. All that said....The Auto Transmission appears to still work fine as I can shift through all with normal engagement. No transmission fluid loss from transmission. (Tcase is of course fluidless) Since this happened, I have driven the truck VERY short distances...Reversed into garage from flatbed tow and pulled forward and reversed again to move the truck to the far side. No Horrible Noises.
Its now on jack stands with the front shaft completely out. I don't want to replace the transmission with a 2wd transmission.. Soooo..Wounded transfer case would remain.
My question.. With the front shaft out if I disconnect the electronic 4wd switch, Leave the current transmission in and basically GUT the transfer case which won't be real hard to do unfortunately. What happens when I try to drive it??.
I got a feeling something about the where the rear drive shaft goes into the transfer case and connects to the spindle or whatever it connects to in the transfer case that connects to the transmission is not going to work very well without the presence of any fluid in the Tcase. Just wondering if any of this crazy no cost temporary solution is even possible. Thanks for taking the time to read and reply.
Chris
