Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sun Apr 13, 2003 5:42 pm
We now only pay $600------$1200 [if pristine body and interior with lots of new parts]. Even a 96Q with a bad motor is only worth $2,000.[hard and expensive to find a take out motor] whereas the 94-95 might be worth $2500 due to easier motor availibility.
I wouldn't diagnose, pull the head, change 4 valves and reassemble for $2400 because if the valves were bad so probably were the rod, piston, and rod and crank bearings on that cylinder.
It might run but for how long, then you get an angry customer, unless you offered no warranty and had them sign a document that they fully understood and agreed.....but then again sometimes you are lucky.
