yeah, i dont really like the t-fitting stuff either. i saw this sandwich adapter that gives you extra sending ports, goes between the filter block (what it screws to) and the block.nissanfanatic wrote:I do a different method for oil feed.
etc, etc, etc, etc
If you drive the car hard, like you should, you may also want an oil cooler.
the guy is selling a s15 bb t28, which i see sell for 400 average, i'd go for everything but the ecu, and get your own ecu setup, so if you could talk him to 700-800 w/o ecu i think that'd be a dealWDRacing wrote:The SR T25 at 12 psi is a heat pump...keep it set to stock to avoid detonation
WD
the thing with the t fitting is to bring it away from the motor, inserta barb fitting and run about 3~6" of oil line to another barb fitting and install it inot the ttramp_drift240 wrote:
and i was considering finding/getting the port block fabbed up, an oil cooler setup, and a filter relocation kit. but that just made me think about how big my oil capacity would be.
oh, and i added the price. 1k.
He's goodneverlift wrote:
also note t2 isnt whats up, T3 FLANGE ftw! I did not believe wd but now I dew hows the cat wd
LAME you already showed me that one, or is it a summerly affairWDRacing wrote:
He's good
