5seryan »
https://forums.nicoclub.com/5seryan-u28168.html
Thu May 11, 2006 3:43 pm
Ok so heres the deal. I have a 95 Q45t. Last summer as some might remember i was in an accident. the front of the car was roughed up pretty bad. Thanks to Wes i managed to replace most of the damaged body panels except the hood. I thought it might be able to be fixed but was wrong. The front driver's side fender was replace along with the front bumper and driver's side headlight.The panels are crimson. the rest of the car is silver. Anyways i have been driving the car like this for a while, waiting for enough money to get the hood from wes and finally get the car painted.
After that I got the dreaded fuel pump problem. I got a replacement from Joe and replaced it. The FCPU was fine. Just recently there developed a short somewhere that continually drained the battery. Then to make things worse the car started to run like a bulldozer. I pulled the codes from the ECU and and got code 55-- Injector. I'm almost postive its bad as the car vibrates when accelerating.
Some other bad things... theres some small rust spots in the normal areas for the Q. The radio antenna is bent and doesnt go down all the way. the rear tail light is falling out and one of the cornering and fog lights is missing. The VC gaskets need to be replaced as they are leaking. And the plugs need to be done.
Some good? The interior is pretty good i must say. Its black leather (obviously?) the only thing really wrong with it is that the drivers side door panel has a spot from the drivers elbow rubbing on it. The fuel pump is new... the oil was changed 3k miles... if you ask wes when he last saw it... it was one of the cleaner Q engines. Theres relatively new rubber put on this winter.
Thats about all i got for now. basically i dont know wheterh someone would be willing to buy it whole or whether i should part it out. Im sure i forgot some things. if you have wuestions just ask. i will try to answer as best i can. if you want to give me and idea as to what parts you would be interested in.. thats cool too. So there it is.
