ghettoslide »
https://forums.nicoclub.com/ghettoslide-u18248.html
Thu Feb 09, 2006 5:47 pm
Dude this mod works. I did like two years ago. cut the brown wire wrap off the ends, bam thats it, put the switch back in. Now turn on your headlights. Hold in the switch you just cut the wire from. turn your head lights off. You lights should stay up. Release the switchand the lights should still stay up. Press the switch and the lights will start to fall, when the lights get to where you want them press the switch again to hold that position. No parts to buy, no anything, and there it is. When you turn your headlights back onthey will drop on down and then come back up and work as normal. To redo sleepy eye hold the swich again and turn lights off. Then repeat what you just did, works every time.
