wa-chiss »
https://forums.nicoclub.com/wa-chiss-u37545.html
Sun Sep 23, 2007 6:55 pm
Header, Exhaust (done), intake (you really only need a K&N drop-in filter), Tune-up, and fluid flushes (i.e. brake lines, clutch lines, transmission, diff, power steering, and the a/c too.)
Header: I've had the OBX for a while now and I like it a lot. Just a little minor fitment issue but nothing to get red faced about. If you can get your hands on a Hotshot header I'd go there but the OBX is close in 2nd. They both have 4-2-1 design. There's also the pacesetter header but that would be my last option. Flakey paint (by design), not to mention it's a 4-1 design. You'll gain low-end torque but no top end like the 4-2-1 does.
Exhaust: High flow cat (not neccessary untill you boost) but can still net gains. The rest you have.
Intake: Like I said, the N/A KA's don't gain much from a full intake but loud noise while reving and a little hissing noise at idle. I would just get a K&N drop-in filter, remove the resonator in the fender, and maybe (if you want) heat wrap the pipe going acrost the radiator.
Tune-up: Cap (perferably w/ copper contacts), rotor (again w/ copper), Plugs (copper cores are fine), wires (nothing too fancy), timing check/ adjustment, seafoam, and maybe a blaster coil (no real gain here but you'll have that "peice of mind") Copper is VERY good at conducting electricity.
Fluid flushes: You probably won't gain anything from here but it's more neccessary than you think. Brake fluid (for brakes and the clutch opperation) is "Hydroscopic" meaning it obsorbs moisture. That brown color you see when you take off the caps is a good (bad really) sign of old, dirty, contaminate rich fluid thats at the end of it's service life. Flush it out and put in new fluid. (DOT3). Power steering is important too. Especially if you decide to race the car. Old fluid has particles in it. Particles that could potenially leave you w/ out P.S.. A/C, well, if you want the creature comforts, you better make sure thier in good working order and condition. Old freon again is full of contaminates that put a drag on the compressor. The more drag the compressor sees while running, the more drag on the motor. You'll never notice it alone but all these things add up in the end. For the transmission and diff, I would drain the fluid, add fluid (cheapo stuff), drive the car for 10 miles or so, drain it again, and fill up w/ synthetic. I (and alot of people here) use Royal Purple, Red Line, and Lucas. All od witch are good products. You should also do the same for the engine oil. Synthetics are up to you. But I recomend them.
