Ace2cool wrote:No, James. N62 MAF is correct for Z32. The Maxima with the VG had the N60 and a funny looking plenum.
For some reason I thought the NA got the N60, and the TT got the N62.
Ace2cool wrote:
Also, according to the FSM, the signal voltage is supposed to be .8V - 1.5V. Yours is low, which is making the engine dump loads of fuel.
His is low because he did it with the engine not running. Also, lower MAF voltage = less fuel commanded by the ECU.
He should be able to follow your steps and check the MAF voltage at the ECU while its running to verify if its the MAF or not (ideally, CONSULT would be great so it takes all wiring and connections into account too).
Pulling the MAF to get it into limp very possibly could disable input from many other sensors, taking the ECU out of closed loop mode and just running off safe maps. If the MAF checks out, I'd start looking elsewhere.
