possible maf problem,i'll paypal someone 5 bucks if they can solve it!
aceof07
Car: 91 240sx
alright now that i have your attention here is my problem, i have a 91 240 with a 93 ka. the issue is that if i get on the gas with the maf sensor connected on the right way i cant rev up past 2500 much like a faulty maf however at about 25% throttle it will rev up to redline. also if i disconnect the ground that leads to the maf the car will rev up just fine but runs super rich because its stuck reading 5 volts. someone give me ideas, I'm DEAD serious about the paypal, i'm desperate here now. please someone help a brother out!
Modified by aceof07 at 5:12 PM 4/28/2009
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
did you test out your TPS?
aceof07
Car: 91 240sx
yes, should be set at .45v right?
aceof07
Car: 91 240sx
well just so everyone else knows, i did the head gasket, and a lot of wiring on the car. all the emissions are deleted. if you have any questions ask! paypal up to 20 bucks now people!
killablue240
Car: sr powered s13 coupe, 1991 twin turbo 300zx
check for leaks in the intake tubing and check for a corroded maf plug.
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
replace your maf... it may be bad.
aceof07
Car: 91 240sx
hmmm, corroded plug i'll see into that... oh and i've tried 3 mafs, 2 of which are known working ones, and swaped out about 3 ecus as well still no change. wtf is going on here? i always keep getting the maf and knock sensor codes on all the ecus. this is kicking my butt.
killablue240
check the maf plug for corrosion and the wiring that goes from the maf back to the ecu very common problem on 240's, also if you clean the connection disconnect your battery for a few minutes to reset the ecu.
onosqv
Car: '92 240sx Vert
aceof07 wrote:hmmm, corroded plug i'll see into that... oh and i've tried 3 mafs, 2 of which are known working ones, and swaped out about 3 ecus as well still no change. wtf is going on here? i always keep getting the maf and knock sensor codes on all the ecus. this is kicking my butt.
aceof07 wrote:well just so everyone else knows, i did the head gasket, and a lot of wiring on the car. all the emissions are deleted. if you have any questions ask! paypal up to 20 bucks now people!
That's what happens when you tinker w/ wiring & emissions - you could have inadvertently created some issues.
I don't know what your definition of doing "a lot of wiring on the car", but you may be better off @ this point returning things to stock.
if ur replacing good maf's & ecu's & still getting maf sensor codes, the only thing left is the maf wiring.
if u haven't replaced the knock sensor & knock sensor subharness, then you should do that as well.
Barnav1t
Car: 1992 Nissan 240SX
aceof07...your avatar rocks.
