I'm glad you took your position. My original post probably got to defensive of Nissan. I'm with you on favoring performance over aesthetics. I do love the dustless brakes on my G37, but I'd never go on track without a major pad upgrade. (I use Hawk HT-10s on my 944 but would use Hawk Blue if I took anything as heavy as the G37 on track.)AZhitman wrote:Right. It's true that if the pads transfer too much heat to the fluid, it boils, creates air bubbles (which compress, unlike fluid), and the pedal goes soft.
Blaming it on the pad compound isa very small part of the problem - The pad compound, with insufficient "bite" will require more brake pedal pressure, which in turn generates more heat, which creates the situation described above.
They failed to expound on the whole problem.
Nissan's brakes have sucked since 04... In 03, a G35 Coupe with Brembo package had a shorter stopping distance than a Z06 - What happened?
There's actually a good article in C&D or MT a few months back about this - Nissan got SLAMMED on their brake performance.
Low-dust / low-noise pads are for retirees in LeSabres, not performance cars.
I love the Ferodo 2500DS pads for the G, by the way - Great track and street performance.
Crash tests should be run in a way that factors in braking, not just damage as a result of impact at XX MPH. Like you said, if I get stopped in 120 feet, 5 feet short of a tree, but some "safe" Volvo would have stopped in 140 feet, well that's 15 feet into the tree!PyR0NiAk wrote:Interesting thread... I find it amusing that you bypassed your own language filter...
The June issue of C&D revisits the Nismo braking issue, and concludes (as you had guessed) that the issue likely stems from too little air being directed to cool the brakes.Potomac-Greg wrote:If a brake pedal goes soft, it's because the hydraulic system is breached. Either there's a fluid leak or the fluid has boiled. (...) I guess this is something to keep an eye on.
My other half wants to replace her 2005 C230K. Stick, good looks, real leather and a "reasonable" price are non-negotiable, so the strongest contenders are the G37S and the Audi A4 6MT. She and I both like the G, but a road on which we often drive requires many strong stops (switchbacks). The brakes on my C350 are often hot when we make it home in light traffic (higher speeds), but fade has never been an issue.PyR0NiAk wrote:How did you even find this?
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
