Possible headlight conversion?
240tek
Car: 89 fastback
Everyone talks about lazy eyes and east bear or AbFlug. I was thinking of something that is sort of a mixture of them all. I like the idea of pop-up or controlable headlights. I also like the idea of flush mounted lights. I like the ab flug design, except I'd prefer round lights, not rectangular ones. Ab flug: What if you had something like that, but it was recessed and not quite flush with the hood. Then you still utilized a controllable cover that would slide over the glass to conceal it. So, when the lights are off, the cover is over and it looks standard. When you turn them on, the cover slides back, under the hood, and you expose the glass enclosure underneath. Inside would be two round HID's. What do you think? Ideas? PEACE. Tek.
240tek
Car: 89 fastback
I really want to do this, or something like it. If you are in cali, I'm willing to get together with you and work on it. PEACE. Tek.
jjwilks240
Car: cars
i know a company in canada is designing some, http://www.cp-racing.ca
theyre not on the page yet, but should be in a month or so
rico05
Car: 1992 RMS13 w/ CA18DET
http://www.cpracing.ca/
You got it wrong.
gabossie
Car: Your mom
NSR (NICO sponsor) actually has one, I just haven't had time to get it up on the site yet (webmaster). It has round lights and looks sick. Watch for it in a couple days.
240tek
Car: 89 fastback
My point is though, that I think it would be unique to have the stock headlight cover over a set of flushmount lights. When the lights are off, it would look completely stock. When you turn them on, instead of turning, the cover slides under the hood to reveal the lights. It's more of a show thing I guess, but it would look nice. Of course the light kit itself would not, technically, be flush mount, since the cover sliding over them in the off position would be flush, but you get my point right? Just think of the headlight cover as though it were a power window. It could be extended and retracted at the press of a button. Instead of being clear, it would cover the actual glass, or lexan, while you're not using the lights. Then slide back, like a power window, to reveal the lights when you need them. Anyone think they could do this? You could probably rig the existing motor up to it, or re-mount it somehow. PEACE. Tek.
Cheetor67
Car: My Car, Car Parts, Money, Shiny Things
That is an excellent idea, Tek! I absolutely love it! Get a patent and you could be in major business...seriously. If you manage to create such a design, please let me know, for I would gladly purchase a set from you...Sounds really amazing...something out of Transformers or something...ya know?
Keep me posted, k?
:uzi David :biggun:
240tek
Car: 89 fastback
Yeah, thanks for the input. I might do it this summer. PEACE. Tek.
erich
I made some custom mounts for some Sylvania Xenarc HIDs. The light pattern was a little weird, but still better then stock.http://www3.telus.net/kreen/headlights.html
Too bad my welding skills made it look like vandals did it.
blacks13ek
I like the look man. The welding on the hood like you said could use work but the finished product is something to be proud of. NICE!
SoCalS14
Car: My car...duh
Have you guys seen how vettes lights "flip-over"?? I think it would look tough to have the flush mounted ligths flip-over to a smooth bottom side....
shawawini
My friend did something that looks very similar to Abflug, but with two 90mm lights per side, one for high beam one for low, similar to the ones on clearcorners.com They look really nice and it was rather inexpensive
wangless
Car: '02 MBP WRX
got any pics of what your friend did shawawini ?
SoCalS14
Car: My car...duh
It would seem, looking at the pics of your headlight converstion, that a Silvia hood (the one that goes with the fixed lights) might fit and give you that look.
shawawini
i dont have any pics of the conversion he did, but they are very similar to the ones on http://www.clearcorners.com
wangless
Car: '02 MBP WRX
hey shawawini, was it like these ? theyre so badass... too bad its like $50 something a bulb... and times that by 4... over $200. go to like page... 5...
http://www.sounddomain.com/memberpage/205203/14
Rex
Car: None
erich wrote:I made some custom mounts for some Sylvania Xenarc HIDs. The light pattern was a little weird, but still better then stock.http://www3.telus.net/kreen/headlights.html
Me likes :D, gotta figure it's cheaper than a Silvia conversion and more unique. What did you use for the metal "inserts" on the hood?
shawawini
Thats pretty much the ones, he got them from susquehanna.com, $50 a piece, 2hi-beams and 2 low -beams. But its a lot cheaper than paying about $1000 for the clear corners.com lights
wangless
Car: '02 MBP WRX
"Thats pretty much the ones, he got them from susquehanna.com, $50 a piece, 2hi-beams and 2 low -beams. But its a lot cheaper than paying about $1000 for the clear corners.com lights"
nice... too bad i dont have $200 to spare or else id do that
erich
I used some steel sheetmetal that I got somewhere. I folded the edges over and welded it on.
240tek
Car: 89 fastback
That's a good idea for the Silvia hood. But I think the front edge follows the line from where the fender and bumper meet. You'd have to see one first I guess. Maybe someone on NICO that has done the silvia conversion can take a photo for you. PEACE. Tek.
shawawini
same here, maybe there is a generic pair of circular 90mm light that wouldnt cost $50 a pop
erich
I measured a Silvia hood before I munged mine. It was too long by about 3/4" if I remember correctly.
SoCalS14
Car: My car...duh
Quote »I measured a Silvia hood before I munged mine. It was too long by about 3/4" if I remember correctly.[/quote]
Would it be tougher to shave off 3/4" or try and weld inserts?
uvamosk
They have that Headlight conversion but it comes stock on the SUNFIRE LMAO.....
