possible group buy, thermostat housing extension peice.
sdtouge
Car: 1990 240sx coupe
hey guysi saw alot of people in the maita world have this, so i was wondering who might be interested if the price is right (low lol).
bascailly, its just a pipe that goes from the intake mani to the thermostat outlet, kinda of a spcaer, so you can put your aftermarket temp gaue sender in there, have it be accurate, and keep the stock sender.
my friend just got a job at a machins shop so im going to ask him about it.
matt
rico05
Car: 1992 RMS13 w/ CA18DET
What price we talking? Anything less than $30 and I am soooo very in.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
There is a very simple solution to this... get a piece of 1.5" diameter pipe that is about 3" long. Weld a bung into it for the sending unit, cut the hose where you want it to go, and insert the pipe. A solution for less than $10 parts and labor.
sdtouge
thats not as accurate.they already make those.
for people that want stock gauge also, and very accurate aftermakrt one working together.
im giving a thermostat outlet to the guy this weekend, then ima test fit it and see how it works, then you guys can order it through him.
Gutling
Car: 1989 Nissan 240sx SE
id be interested if u could rig one up for sr's too. i was going to get the rad hose with the bung, but it would be nice to keep factory temp working.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
hmm we are about to finish out mini CNC machine, this wouldnt be a bad product to try .
float_6969
I'd be down. Currently, mine never reads over about 165*. I know thats crap. It's about 20* offacross the board. Grrrr
sdtouge
yea not a sr if you wanna do this, and need a extra outlet i can ship this one out.
mikehutch711
im down
tyrannix
Car: go big or go home
im all about goofy extra things that make life easier or improve something
zero_gripS13
Car: soon to be 95 s14 hopefully
wheres the best place to put an aftermarket temp gauge.. and why is it so unaccurate?? what if u put it in the lower rad hose?? or should it be in line with the thermostat..?
sdtouge
lower rad hose would be the worst place to put it. if its on the other side of the thermostat, after it, its not always reading coolant flowing directly out of your engine when its closed. putting it before the thermostat will read the most precisely and constanly be getting readings from the coolant directly in your engine.
zero_gripS13
ok then what makes it less accurate putting the gauge withing a couiple of inches of the thermostat?
