Possible fuel injector problem, car is not starting
krazy88
Car: 1989 240sx
Last friday my 1989 240sx SE (standard) died and it wouldnt crank. So i towed it home and ordered some timing parts from nissan because it was having issues prior to the breakdown. I replaced the tensioner, guide, chain, water pump, and thermostat. It is all timed right, including the distributor. I am getting good sparks from all for wires. I turned the key and floored the car until the battery started dieing (while being jumped). Took the sparked plug out and there was no gas at all on the plug. I am getting good fuel pressure before the rail and injectors. Has anyone had this problem? If there is already a thread out there to answer my problem, if you could direct me to it that would be great. I searched, but wasnt quite sure what to search for. Thanks for any help.
Modified by krazy88 at 7:56 PM 10/25/2007
