Possible frankenstiens?
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
namwons_240
Car: 97' 200sx ser
is it possible to mate the gti-r itb's on a ve head with only minor mods for a killer N/A setup?
OR:
can you mate the ve head to bb/avenir block for sr20vet? or even possible vet the gti-r motor w/itb for a super nasty turbo motor?
JustinVero
Car: 2 1996 Nissan 200sx SE-R's
namwons_240 wrote:is it possible to mate the gti-r itb's on a ve head with only minor mods for a killer N/A setup?
OR:
Im sure its possible to use GTiR ITBs on the VE head, as its been done on a regualr DE before. However, you may be better off using ITBs from a motorcycle to make better all-motor numbers if you are gonna go all out.
It is possible, and relatively easy to put a VE Head on any DE/DET block, you just have to drill and extra hole and run an oil line to supply oil for the cam switch over.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
