Post by 240 Doubledrive » https://forums.nicoclub.com/240-doubledrive-u17114.html Wed May 25, 2005 6:55 pm
Post by b18onboost » https://forums.nicoclub.com/b18onboost-u22410.html Wed May 25, 2005 10:48 pm
Is teh turbo new or used? A simple test is to take ur feed and see if oil is coming out of that. If so then i guess you could say that ur t28 is busted.240 Doubledrive wrote:I just put in my t28 into my s13 and I got an oil leak on the oil feed line off the block. I messed around with it for days with different copper washers before and after the banjo but it still leaks. Could it be that my turbo is clogged and oil wont go in? The return line is dry..
Post by Hijacker » https://forums.nicoclub.com/hijacker-u9394.html Thu May 26, 2005 2:23 am
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
