possible fit awd coilovers on a Rwd m35?
Cabo
Car: Infiniti M35 sport 2006
Nissan pathfinder LE 2002
My buddy said he would give me his awd coilovers if they would fit my rwd m35...
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
This will not work properly. Shock bodies are different lengths and design.
svard75
Car: 06 M35x
Fronts will not work, rears will.
Cabo
msvara wrote:Fronts will not work, rears will.
Are you positive because I know someone selling front coilovers for rwd brand new because they shipped him wrong ones. Can I use the red frobt coilovers and the awd rear coilovers
Cabo
Are you positive because I know someone selling front coilovers for rwd brand new because they shipped him wrong ones. Can I use the rwd front coilovers and the awd rear coilovers
RED_DET
Vendor
2011 Infiniti G37x
The front shock is completely different on the AWD vs RWD.
svard75
Car: 06 M35x
Let me rephrase what I said earlier. The coilover package your friend is selling which is for AWD will not completely work on your RWD M35. The reason is the front shock bodies are shorter and the spring rates are higher. The rear coilovers are exactly the same between the RWD and AWD version so you could use 50% of his kit. The issue is you can't buy just the front coilovers so either way you look at it you'll need the entire kit.
This is what the front of a RWD M35 shock looks like
This is what the front of an AWD M35x shock looks like
svard75
Car: 06 M35x
Hey Cabo. Was thinking about this and they may work if you can find oem bottom wishbone strut mounts from an AWD. Although the spring rates will be pretty aggressive and make it too bouncy or stiff. I mean if you want to experiment and try them that would likely work.
mr_luv
Shot you a PM Cabo...
Cabo
I know this is old but just wanted to make sure that the rear coilovers of the m35 awd and rwd are the same??????
Cabo
svard75
Car: 06 M35x
Cabo wrote:I know this is old but just wanted to make sure that the rear coilovers of the m35 awd and rwd are the same??????
They are
patmcd06
Car: 2007 M35x
Hey Cabo, does your friend still have the AWD coilovers? Would he want to sell them?
