Possible dumb MIL question
OzoneEnts
Car: 1995 G20
I am the one-day owner of a 1995 G20 with 127k.
Today I checked fluids and removed the air filter to inspect it. After replacing the filter and driving on a short trip, the "malfunction indicator light" illuminated upon starting the vehicle again.
Is it possible that somehow when taking out the air filter I disturbed something that might make this MIL come on? If so, can anyone offer suggestions as to what I should try?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Welcome,
First we need to figure out what code it is actually throwing. Yes it is possible you disturbed something or didn't hook the MAF back up correctly.
OzoneEnts
Car: 1995 G20
I simply unhooked the four clamps holding the air filter housing and lifted it out of the way so I could take out the air filter. I did not disconnect any wires or anything else.
I did notice the rubber hose going from the air filter to the throttle body (?) has some cracks in the accordian-like section. I wonder if air could be coming in there.
Is it possible to check the computer code using the info at:
http://www.troublecodes.net/infiniti/
Can a '95 G20 be checked using the "without OBD II" method? I'm not sure what this ECU looks like or where it can be found behind the center console.
Thanks for the help and welcome.
nametakennow
Car: '06 MINI Cooper S
If the cracks allow any air out, that'd be a bad place to have a vac leak. Replace it and see what happens.
OzoneEnts
Car: 1995 G20
I read and reset the CEL using the procedure given elsewhere. The code was;
33 - "heated oxygen sensor"
Does anyone know the significance of this code?
nametakennow
That means your O2 sensor is bad. Replace it.
RED_DET
Vendor
2011 Infiniti G37x
OzoneEnts
Car: 1995 G20
Well, that sucks after one day of ownership.
Red_Det, forgive my further ignorance but what does "+1 " signify?
How many O2 sensors are there, how much does one cost and anybody know a good parts source?
Thanks for all of the help.
2000 G-Twenty-T
Car: 2000 G20t
OzoneEnts wrote:Well, that sucks after one day of ownership.
http://www.automedicsupply.com...-2.0L
and "+1" means "i agree with the post above me"
RED_DET
Vendor
2011 Infiniti G37x
You have two o2 sensors. One on the exhaust manifold, the other is located in the catalytic convertor.
nametakennow
You could look up the code in an FSM (link in my sig), though the code reader should say, and figure out which O2 needs replacement.
