Seriously, guys that are new to this idea need to read this thread because obviously nobody searched for "oil orifice".
zerothread?id=189416
Before everyone gets carried away with this modification, please remember everything else that is associated with it. If you are planning on having a high hp (550+hp), extended high revving motor, have already done or are planning to do the JUN crank collar modification (required to pull the crank), and know that once you pull the head that you will most likely have to machine the head and block to install a metal head gasket to give you insurance when pushing for 550+ hp, you are most likely in for a complete rebuild.
THIS IS NOT A "WEEKEND TO PULL THE HEAD" MODIFICATION. So don't think, "WOAH! Only $6 to improve the reliability of my RB!" If you are planning on fully rebuilding, then do it. Otherwise let sleeping dogs lie unless you happen to have a boat load of money laying around to do a rebuild unexpectedly.
If you find yourself getting excited about this modification, don't. Go back and realistically reevaluate your power goals and then decide. If you still think you need this modification, proceed to a japanese parts website like nengun or greenline.
