07wHiTE 3.5SE 6sPD »
https://forums.nicoclub.com/07white-3-5se-6spd-u79518.html
Mon Apr 28, 2008 1:29 pm
front and rear is like 2200 for the set i believe.... ap racing was too much...later on you can save money and buy a used g37 oem bbk if those guys ever upgrade to 6 piston or anything.... the brakes work really well...when they introduce aftermarket rotors and pads for the setup even better.... plus with the 14" rotor and bigger calipers, the kit may even be comparable to an ap racing configuration... with cross drilled rotors, pads and stainless lines... which will cost you less, because then you'll only need to purchase the calipers and save money on the remaining items.
