possible bad starter?
greengumby
Car: 2002 Pathfinder- "ole Rusty"
2006 Honda Pilot
Hi ALL :
I couldn't find a thread on this issue so I'm posting this ... when I crank over My pathy the starter kicks in and suddenly stops..a second a second then it starts up..
Possible bad starter or I just realized it might be a weak battery .. I haven't changed the battery since 2011....
Any ideas where else I should check other than the obvious ? :gotme
frapjap
'07 Subaru Legacy
You're on the right track. It sounds like a drop in voltage somewhere. Start with the battery, but also trace the cables to the starter and make sure the solenoid connection and ground to the starter are tight. If that is all good, have the battery tested at your local auto parts shop.
greengumby
2006 Honda Pilot
Thanks for the Info Im going to check this tonight it happend again this morning after i drove it to the gas station a good 10 minute run from the house :)
Cheers
JPK Omaha
Car: 2003 Qx4
Mine does the same thing about once a week, when restarting a warm engine. It has been doing this for several years and it always starts. I had the battery replaced and it still occurs and I attribute it to the starter.
