Possible Alternative to 300zx brakes?
dstrcto
Car: '92 240sx SE Coupe - '95 Acura Integra SE
I've been researching the 300zx brake swap, and while I already have a set of used calipers I was looking into rebuilding them. I was searching part number 41120-30P25 in google and I found this:
Dorman D352024
Dorman lists this rebuild kit for not only the 89-96 300zx, but also for 93-95 Supra and 96-98 Supra TT...
Out of curiosity I googled the supra TT calipers and found this:Front:
Rear:
I got those images from here
Anyone have a set of Supra TT calipers they'd be willing to test fit on their 240?
Edit:
I'm still doing more research:
Cardone PN 191893 is a 96 twin turbo caliper shown here:
Cardone PN 191674 is a 93 300zx NA caliper shown here:
Kinda looks like the mounting bracket is the same, but the line is different... and the centerline of the supra pistons looks to be pushed out more, requiring a larger diameter rotor. Can't tell from pics though, need some measurements lol
Modified by dstrcto at 10:32 AM 12/19/2009
r3v_v3ng3
Car: 91 fastback ka-t
it probably use the same pistons and seals but the mounting point, pads, clearance etc is not the same
it will be a good find though if theyre the same. btw the z32 brakes (n/a or turbo) are probably cheaper since they produce more than the TT supras
dstrcto
True true... they look a bit bigger though... so while they may be more rare, they may offer a larger "OEM" solution... I dunno. If I had a set handy I'd test the fit. *shrug*
Edit: by larger I mean they'd fit a little further outward from the center of the hub, making the rotor diameter larger
