I have a chance to get my hands on a 300zx 2+2 Automatic for a straight trade for My 2000 Saturn SL1 5 speed with about 255xxx miles still drives and runs just burns oil..
This is a direct quote from this guys email.
"ok , Everything possible i know of that needs to be fixed , It does need new tires , only two of them have good tread on them, two are about bald , paint , the passenger window (which i looked up from safelight about 250$ , unless you can get one at a junk yard or someone parting out a 300 which id say would be cheap as f***) , brakes need to be bled , the air control gadget plastic mount is broken , previous owner put black tape around it to hold inplace (which seemed to work till i took it off :p) , the fans need to be installed on it , the guy gave me two medium sized fans that need to hooked up in the front(zipped tied and hooked with the electric) as far as the motor , goes , idek , from what i can tell it seems to be a timing belt problem , and a bad coil. the gas cap also is wierd , it creates a suction so it needs a hole , or a new cap something idk. easy s***. anyways , the easiest stuff , would be replacement of the coil , brakes , gas cap , and interior, and tires. The only thing i could find that would be hard is the window, and i forgot to tell in the ad , but the driver side power window just went out , idk if its jammed , or a fuse , but i rolled it down showing someone , and it wouldnt go back up for some reason. And thats about as far as my knowledge goes." end of quote
suppsedly chassis has 140xx and motor has 94xxx
i will post some pics as soon as i can
