yep exact ones, i guess ill just keep a watchful eyeCMG wrote:Are these the coils that jhot is selling on ebay for like $300? Yeah, I'd only use those for parts. $300 is a good price, but rebuild will cost more, and you can find good not blown used sets for around $600 or so.
Your best bet is to put your your on a lift and check all gear underneath if anything is loose. I also had some clunking noises whenever hitting bumps or doing some harsh driving and put my car on a lift and found out that my adjustable coilover locks were loose causing the spring to have play in it.2LO4URHO wrote:What are the symptoms exactly that lets you know, you have some blown coilovers? I did Some amateur drifting in a parking lot the other week and ever since then I keep hearing weird noises coming from the front- I have a basic Tein coilover set up front and back- not sure if they're causing all the racket or something else like tierods or something- I'm still driving it but it keeps getting worse.
