KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sun Dec 24, 2006 11:11 am
Stop and think about this for a second.
A venturi creates a low pressure system on the backside. As a result, the front side (entry) of the venturi is going to have increased pressure, when compared to just a same-sized piece of pipe.
So, now, you're reducing the delta P across the turbine wheel by backing up the ehxuast pipe with this venturi section. Reducing the delta P across the turbine wheel gives slower boost response, higher exhaust manifold pressure, higher EGT's, etc.
Just something to consider.
