positive camber
christopher12
Car: 1996 240sx
im sick of uneven tire wear on the s14. what do i need to run more positive camber on the rear? what parts do i need to order?
sliderman240sx
Car: 89 240sx : being converted to rhd as we speek
97 240sx kouki need 5-speed
i bought the godspeed sway bar,ruca's,torsion rod kit on ebay. I paid like 300 for them. the get an alignment and have it set the way you want.
Razi
Car: Moo
You're getting uneven tire wear due to bad toe alignment.
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
Razi wrote:You're getting uneven tire wear due to bad toe alignment.
this ^
Razi
Car: Moo
Although I probably should reword that.
But, if you're lowered a lot and don't have adjustable rear toe rods, you're going to get premature wear.
mixeds14
Car: 240
^^^^^agree.. im goin true that aswell, good thing my toe arms are on the way....
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Agreed if its not lowered you need to have it aligned and they use the cam bolts to adjust that. If lowered you need RUCA's
SiDwAyZ240
Car: 95' SR Slayer, '02 LT Tahoe, '03 Chev Express is the DD
Sliderman- Did you have any problems with the godspeed rucas hitting the strut? Mine cleared but were very close, when I took them for a test drive I looked and my damn strut now has a dent in it. No bid deal cause they are blown anyways but I'm trying to get it worked out before I dent the new set.
OutToWin- Can you only use adjustable RUCA's when the car is lowered? I'm wondering if that is my problem, didn't really need the adjustability but figured I would just upgrade to avoid replacing all of the bushings in the stock ones. I measured bolt hole to bolt hole so they are the same length as the stock ones but I just can't figure out why they are so close.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
No but most guy arent dialing in negative camber more than the cam bolt allows with stock ride height. FYI I got those RUCAS too and no issues with my coilovers.
sliderman240sx
i didnt have any fitment issues with my rucas. if its just a little dent try the megan coilovers i know the diameter of the base isnt as large as stock. my shocks are also blow just fyi.
christopher12
Car: 1996 240sx
its that famous rear tire lean that all s14s have..so your saying i need rucas?
christopher12
Car: 1996 240sx
ok guys i went on enjuku racings site and there isnt anything called a rucas..upper and lower control arms and toe rods is what they have and traction rods. so what do i need guys
Razi
Car: Moo
Upper control arms + toe rods.
RUCAS stands for Rear Upper Control Arm.
