posibilities
jdf28045
have found a ca18et and woundering if i can convert it for a et to a det. will the head for the ca18det fit on the ca18et?
Daunttless
Nope.
Red Lightning
Does the CA18ET and the DET share the same engine mounts?
Daunttless
Not sure, I believe so.
jdf28045
different bolt pattern or what? is there any way to convert it to det? or am i going to be stuck with the single?
boost_boy
Quote »will the head for the ca18det fit on the ca18et?[/quote] Actually, it will fit, but the amount of money spent modding the timing belt tensioner area and reconfiguring rods and pistons may not be worth it. Considering you have the money to play with a possible full CA20 swap, anything is possible with dollars. And I'm almost sure the head will need to be machined to match the bore of the CA20's block (Could get expensive$$).Quote »have found a ca18et and woundering if i can convert it for a et to a det[/quote] It's not worth the hassle. Just get the DET and save yourself the dramas.
Daunttless
Hehe, by fit I figured he meant put it on and have it work. =P
jdf28045
ok in that case could I go with a long block and keep the trans. or is that also a loss? I also have to assume that if I go that the way of the full swap that I will also have to invest in a new ecu and redo the wireing harness. is that so? Will the turbo and the exaust system swap between the two? lastly dose anyone know the power out put of the single over head cam? what is the power difference between the two?
thanks guys
themadscientist
almost a 50hp difference
jdf28045
any real numbers?
I fond the car and it runs. it is in a junk yard. the owner of the yard is a friend and will let it go for $200.00 you guys think that I should buy it?
boost_boy
you could actually buy the car (granted it's in good shape) and I guess drive it until you're ready to upgrade. The ET and DET's turbo system is not interchangeable because of the different head design and the crappy turbo that the ET has, not the T25 is all that much better. You could buy a CA18DET motor complete minus a complete harness and ECU and go with a simple standalone system. But if not, you can use the DET harness and ECU and let JWT square you away to some degree.
Bizz
200 bucks? Is it a old 200sx?
jdf28045
ya it runs little body rust but everthing else on it looks good. have pics. if you want to see them.
boost_boy
Post 1 or 2 let us peep!
Bizz
Buy it. Rally the f*** out of it. Replace motor with det, rally it more. Is it an independent suspension model?
Bizz
go here http://www.car-videos.com/impr...ar173 and check out car 173 tearing it up
jdf28045
yes it is indepentant suspenion
Bizz
Right on. Where do you live? I might need it for a parts/race car.
jdf28045
how do you post pics?
jdf28045
oh in marland usa
Bizz
Ouch thats a bit far to pick up a partsmobile. to post a pic off the web somewhere else put "[img]" http://www.random1233123pic.com/S12.jpg "[/img]"
hahaha randompic is a p0rn site :rolleyes
jdf28045
jdf28045
Bizz
hmmmm that sounds rightno spaces between the img tag and the addy though. also is it .jpg.jpg?
jdf28045
ok lets try that again!
[img] http://www.wicomicohumane.org/...g.jpg[/img]
jdf28045
[img] http://www.wicomicohumane.org/...g.jpg [/img]
jdf28045
jdf28045
minor rust on the body. I plan on rebuilding the body in carbon.I dont know the engine looked new so I dont know how bad this looks. I am planing on replacing everthing that is rubber, changing all the fluids and checking the timing belt before I even move it. any other sugestions?
jdf28045
this is a picture of one of my peaces that I am working on. I have weaved fiberoptics into the clear coat of the carbon fiber peace. That way the car appears to have no markings on it untill I hit a light switch and all the emblems glow through the clear coat. this peace was not finished when I took the pic. but I am almost done with it now. that ****er took about 14 hours to wire.
Bizz
Ok first that carbon fiber with optics is badass. Good idea on the rubber and t-belt. you should also check the brake and clutch res. Do a fluid flush for WAY better feel. also see if your steering rack is leaking......mine was but i put in a stop leak PS fluid and it stopped. then you should pull all your ac stuff.....unless it workes. It's actually a good bit of weight. Next thing to do is join http://www.club-s12.org/ .
Man seems to be a lot of interest in the good ole s12 these days......I wonder if somebody else will beat me to the det swap. :dogpile
