SRdave240 wrote:When I had mine off to fix my exhaust leak I gave it a little cleaning of the casting lines and smoothed up the ports a little bit. It didn't really seem to make much of a difference. I took off very little material though.
I wouldn't bother. If you are putting down less than 300whp it doesn't really help. If you are putting down more than that, even a cheap tubular manifold will give you MUCH better gains.
msaskin wrote:The exhaust will still swing. Short of welding the entire exhaust setup to the frame at multiple points you aren't going to keep it from moving around.
