That's only applicable for carbureted engines. SFI engines won't have that problem due to where and how the fuel is injected.iliketocrash wrote:i was always under the impression that removing the casting imperfections in the intake side is a bad thing because the imperfections actually promoted fuel atomization and prevent the fuel from puddling. i'm just saying what i heard i'm not knockin' your port job. it looks great, especially for a dremel. how many hours did that take you anyway?
im sorry but i dont know wat this is can some one enlighten meSSS wrote:I suggest you lightly radius the sharp edge of the quench pads in the combustion chamber to eliminate potential hot spots.
No. Not with the sharp angle that the KA intake side has. I had my head's intake side roughed up and the power was definately more reliable and even. I was recommended this by deviousKA a while back and he was right.InsanityInc wrote:That's only applicable for carbureted engines. SFI engines won't have that problem due to where and how the fuel is injected.
2BN_S13 wrote: You get a better mix when you do it right like I told you.
Who are you? No seriously, I've never conversed with you before.
Modified by 2BN_S13 at 4:40 AM 9/27/20052BN_S13 wrote:Why did you go and mess that head up like that?
Im serious, you did the intake all wrong! You are supposed to roughen the intake, not polish it.
You have a point there with a n/a set up, but this head is for turbo duty, so a rough intake does not concern me @ this point. Actually if you look alittle closer on the intake, it is a "touch" rougher then the exhaust or CC, when have been polished.
I have heard DeviousKA is the authority on these motors & would welcome his comments, & thanks for yours.
Kb
I thought that the intake is supposed to be gasket matched, not polished.Dammitboy wrote:
And about the intake ports, your right partially, you want to remove the rough cast finish, removing obtruisions like valve guides & valve seat ridges to improve flow. However, leaving enough of a slighty abrasive "touch" finish to help keep fuel from puddling.
I think you meant to say gasket matched for PORTING, not for polish.The only time I see polishing is in the pentroof chamber, and exhaust ports.Always use a larger grit on intake.Intake on N/A needs turbulance an swirl one of the reasons why the grind used on intake is much grittier. It also matters that it has a rougher surface on intake because the injectors inject in the runners before the head. On direct injection it doesn't matter as much, and on direct injection it is noted that it is better to have less rough porting done to intake.Exhaust ports are to be polished to increase exhaust flow.I wrote a report on this and aced it, I got alot of my info from standard abrasives.http://www.sa-motorsports.com/diyport.aspxdkdeleon68 wrote:
What is this Radiusing and quenching you all speak of? Please explain!DjPantsSpecR wrote:good post, although i think its been brough back from the dead
but good post Vinnie, that article is VERY helpful. i think i'll be doing most of this work, like radiusing the quench area and some bsic port/polish while my motor is apart. danke
You failed to mention that radiusing the chamber also makes a larger flame front by pulling air and fuel mostly to the center of the chamber, thus slightly increasing combustion while also decreasing the potential for knock and ping. Radiusign can also cause the intake CFM to increase as well, which could also be beneficial for swirl. The reason why radiusing isn't always done is because it also shrinks combustion space (quench area) just as clover leaf welding does, and on streetable cars that aren't finely tuned it can increase HC's, if you are concerned with the enviornment as much as california tree huggers do.I have seriously been considering radiusing, and clover leafing as it is becoming almost time to rebuild my block which has run passed 150,000miles.Benefits to radiusing and clover leafing is that unlike a milled head that raises compression, it leaves much more room for valve lift. Where as a milled head will more than likely leave you with stock lift/duration. Clover leafing and radiusing can also run as high as a 13:1 CR. Which in this case is also much more beneficial than using raised dish pistons which also prevent any kind of dramatic valve lift.Radiusing and cloverleafing is the way to go for a KAde head where as if it was a hemispherical roof chamber it would be much more beneficial to get raised dish pistons, just as many heme engineers have done.DjPantsSpecR wrote:i'm building a high compression motor, so it would be to my advantage to polish the combustion chamber and the exhaust. however, radiusing these quench area corners and any other sharp corner i can find can reduce the likelihood of hotspots caused by the large surface area small mass spots. this can help a little in reducing knock. which i will need for my current fuel system and high compression.
