porting head question
corey240
Car: 1993 Nissan 240SX Base Drift Machine
so you can port your head by grinding the ports out with a dremel or equivalent tool? or do you need a specific way to do it
Ohsoclean240
Car: 1991 240sx coupe
it would take too long with a dremel, and you wouldnt have the reach or power to do it right.
Blown240sx
Car: 1996 240sx
The gains of porting on a SR head are very minimal and not worth the time nor money. You already have a head designed by nissan for forced induction. Porting it really wont make it flow that much better.From the research me and my buddies have done your better off port matching your intake and exhaust manifolds and leaving it at that.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Yikes! The SR head needs something for better flow though.
Ohsoclean240
i plan on porting the **** out of my headthe way the head flows is a ****ing jokelooking at an sr20det head makes me miss my race ported gsr head
Blown240sx
Car: 1996 240sx
Ok well you show me some dyno numbers of ported SR head vrs Stock on most of the setup the people on here will run and Ill show you why they $1000+ job of a good port isnt worth it.
If your going all race yea port is good but for the majority of people on here that have a GT2871R at the most its not worth it.
Also GSR Im guessing Integra? NA honda motor vrs a Nissan Turbo motor... Of course a GSR would need a port.
Ohsoclean240
i dont use anything off of the shelfright now i had a custom garrett made that i should be running in a few weeks. i'll be using BC 272 cams (i want to try the crower 288 na profile but i odnt know how they would perform)
sleeves, etc eventually
Blown240sx
Car: 1996 240sx
point proven. Your building a nasty motor. This guy probably still is running the stock turbo.
Ohsoclean240
true. i think anything t2 based is a waste on these motors.
my motor should be pretty bad if i can ever get it done.
redtop91
Ohsoclean240 wrote:my motor should be pretty bad if i can ever get it done.
Quoted for understatement! Make a thread once it is done.
Blown240sx
Car: 1996 240sx
What managment do you plan to run cause 272 is a great cam but 288? Id be interested to see if the thing would idle lol. 272 will give it a nice lop idle.
Also I agree with ya on the turbo size. I just got my GT35R (ported and clipped) and I love it. 2nd gear now wont get traction if I dont ease into it.
Ohsoclean240
most likely an aem ems.. i ****ing hate MAF.i want to try bikirom for now, because an option to use a map sensor should be released soon.
1600cc injectors, 288 cams ( i want to see a cam card first)i have a gt3537, should be nuts
Blown240sx
Car: 1996 240sx
AEM is a good system. I liek the Power FC but it is a bit limiting but easy install. But I personally dont need anything more agressive than it since Im running under 500hp and dont need to rid myself of the MAF just yet (even though I hate it).
also 1600cc lol those are bigger than my buddies secondary injectors on his Rx-7. He was putting down around 400 whp.What top feed setup would you go with since I dont know of anyone who make 1600cc side feed? Id recommend aeromotive for fuel things. I love there products.
Ohsoclean240
i have an a1000 pump, 20 gallon fuel cell. 10-an feed 6-an return and an aeromotive fpr
greddy rail, precision injectors
Blown240sx
Car: 1996 240sx
Sounds almost exactly like the setup my buddy is running on his Corrado. Hes got a 3.2L VR6 (fully build head and bottom end) and transmission (AWD setup) out of a R32 golf, GT45R turbo, Autronic, MAP, Intake and exhaust mani, 1200cc injectors and a bunch of supporting mods. His aims are 800-1000hp
Ohsoclean240
i'll make 450-500whp on pump when i get the build done
karmakaze
Car: 98 240sx SE
i thought about porting my sr20 and upgrading to a top mount. but i have decided to keep my bottom mount gt2871r .86, and just bored my sr out to 2.2 and replace the springs in my head as well as port match my intake and exhaust. (btw the entire motor has been cryo treated)
spider_slayer
Car: S14 240SX
S13 240SX
karmakaze wrote:i thought about porting my sr20 and upgrading to a top mount. but i have decided to keep my bottom mount gt2871r .86, and just bored my sr out to 2.2 and replace the springs in my head as well as port match my intake and exhaust. (btw the entire motor has been cryo treated)
is your motor in the other shell yet? i'd like to see how a 2.2 pushes that gt2871
Ohsoclean240
depending on the turbine housing.. about like a t25.
its gonna come on heard but depending on boost levels may fall off a psi or 2 up top
karmakaze
Car: 98 240sx SE
spider_slayer wrote:is your motor in the other shell yet? i'd like to see how a 2.2 pushes that gt2871
not yet. actually i am still waiting on the cryod engine to ship. then its off to the machine shop.
Ohsoclean240 wrote:depending on the turbine housing.. about like a t25.
its gonna come on hard but depending on boost levels may fall off a psi or 2 up top
turbine housing is .86
I am thinking it will spool by the 2800-3000 i hope at least. normal driving will be 17.5psi and spirited i am planning for around 22psi with a redline of 8000. I am hoping it won't drop off to bad up top. but if it does, I am not against changing my turbo setup later on.
with my 4.36 gear ratio I expect it to be pretty mean down low though.
Modified by karmakaze at 12:59 PM 1/3/2007
Blown240sx
Car: 1996 240sx
karmakaze wrote:with my 4.36 gear ratio I expect it to be pretty mean down low though.
And your pocket book hurting from gas prices.
Ohsoclean240
yea..i cant wait till we get e85 down here... omfg. cheap gas plus more power than 93 FTW
Blown240sx
Car: 1996 240sx
e85 requires different A:F ratios I believe than gas but yes it has 112 octane.
Ohsoclean240
*cough* tuning *cough*
redtop91
Yikes. I didn't know that about e85. (Now for an intense Wiki session)
Ohsoclean240
on some turbo hondas we saw 100whp gains at the same boost levels
karmakaze
Car: 98 240sx SE
Blown240sx wrote:And your pocket book hurting from gas prices.
eh, it happens.
redtop91
Ohsoclean240 wrote:on some turbo hondas we saw 100whp gains at the same boost levels
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
i thought i read somewhere that E85 will **** up the fuel system or engine. could have been a rumor.
