porting and polishing ??
whyteboy
Car: 92 240sx coupe
so im building a ka-t and i have all the parts i need to build my head im going to do a valve job but i want to port and polish it too. ive heard that thats bad for the ka heads because the ports in the head are already enough and polishoing it would lead to bad turbulance flow in the head. i dont know if this is true or not i would like to hear your guys input and what you guys did to yours thanks for the help
churro
Car: RHS13 ('89 Hatch)
Here's something I came up with in a searchhttp://forums.nicoclub.com/zerothread?id=162991
480sx
Car: 1996 Pearl White 240sx
Not trying to be an *** but what you heard is complete garbage, dont buy into it.
rx-007
porting and polishing can never be bad if its done right and will help increase volumetric efficiency an almost any factory car. Because the ka block is factory made you can expect that the parts such as the manifold have resistance based on the rough flow characteristics vs a ported and polished one. You are spending more time on an area the manufacturer didn't.
whyteboy
Car: 92 240sx coupe
i htink im just gonna do it what could hurt i dont think its gonna have any type of negative affect thanks for the input
ilovecoupes
i think if you gasket match and simply clean up any casting imperfections you should be fine
you shouldn't go crazy with the dremel unless you have a flow bench.
this was kinda discussed in this thread I made
zerothread?id=282305
eazye2000
Car: S13 KA-DET
ilovecoupes wrote:i think if you gasket match and simply clean up any casting imperfections you should be fine
That's exactly what I did. I also made a thread about my 'Port and Polish' ventures. Lots of pictures too. And a lot of useful information in there as well. My car runs pretty darn good, with the exception of having stock cams.
zerothread?id=222752
BoostFab
Car: S13cp, S13fb, S14z
whyteboy wrote:i htink im just gonna do it what could hurt i dont think its gonna have any type of negative affect thanks for the input
go back and b-slap the person you heard it from. bad judgement and misinformed usually = blown motor. good luck.
480sx
Heres your reason to leave port/polish to the pros. When you take out more metal on one port than the other, that cylinder will consistently get more air than the others. This will cause a cylinder to constantly run leaner than the rest. It will be your motors weak link, when you get a boost spike, or whatever that cylinder will be hit the hardest.
Best thing you can do if you wana screw around with your heads is to take the casting marks out. This will allow your head to breath better without risking an unbalanced head/motor. Also, polishing the exhaust side can be beneficial.
I guess what im saying is, dont take a dye grinder and start going nuts on your head, you WILL do more harm than good.
whyteboy
Car: 92 240sx coupe
i didnt get it done yet but im not doing that myself im sending it out to this guy that did my boys galant vr4 head. i have stg3 dc cams with dual valvesprings and nitrade valves (i think thats whats its called lol) but yes itll be done looking for a shell wrecked my coupe so im on the lookout for a new coupe if not ill go with a hatch.
Zippy69
Car: 1993 240sx coupe
Port match = yes, do it yourself. Just matching your port to the gasket.Porting and polishing for yourself= NO!!! If you don't know what you are doing you can screw up big time. Leave it to a pro with the right equipment and knowledge.
whyteboy
Car: 92 240sx coupe
yea thats why im not doing it and getting it sent out i need a valve job also so im doing everything at once
silviaS13lover
Car: yellow llama onevia
yea im getting one on my dohc soon. since i work at chevrolet, my local machine shop is doing a full p/p for only 150$. and to reground cams is like 45$ each. the shop has been there since the 60's, so they have a good rep.
ilovecoupes
silviaS13lover wrote: and to reground cams is like 45$ each.
WOW, that is an awesome hook-up. I was looking to possibly get my cams regrinded and its like $250+
whyteboy
Car: 92 240sx coupe
wow thats a really good hookup i hate you lol
