Fearsome_tea »
https://forums.nicoclub.com/fearsome-tea-u62670.html
Thu Apr 19, 2007 11:57 am
As you know it stock the 25 head is hyd and the 26 head is solid. Just wondering if any on has put stock 26 cams in a 25. Talk about fun. These things sound mean at idle and has mad top end. In a 26 they are small but in a 25 being that the lifters are hyd, they tend to throw the valve open much more then in a 26. Just thought I trow that out there. Today I began to port and polish my 25 head and being that RBs are 26 valve 6cyl is a time consuming job. I am also polishing the bowls. I will be keeping the squish points for high compression. Since I am using a Tomei 1.2mm head gasket I am having a local machine shop shave the head down 0.2mm when I am done.What a tyipcal head looks like before.What I use to clean it.(works really good)After I cleand itStarted to smooth out the bowlspolishing the bowl
