you would see gains from porting or extrude honing it. extrude honing is obviously your best bet as stated previously, but you'd be better off spending that kind of money on making a new intake manifold plenum and shortening the runners.
I'm including this because its reputable and good info, from
http://www.grapeaperacing.com:
"Your goal with any port modifications shouldbe to get as much flow and velocity as you can withas little restriction as possible. When working on aflow bench, pay close attention to how much metalyou remove and how much the port flows. If youhave a 100 cc port that flows 100 CFM, then youmodify the port by grinding 5 ccs of metal away andthe port now flows 110 CFM, you gained flow andvelocity (a good thing for a street engine). If yourmodified port flows 103 CFM, you gained a little flow,but lost velocity.
You will need to cc the ports often andmeasure flow often to get good results. If you don'thave access to a flow bench, it's best to remove aslittle metal as possible. Most pocket porting jobsgive very good results when less than 5 cc's of metalis removed. More than that, you need a flow benchto see if what you're doing is helping or hurting."
also this about intake runner length tuning
"Forsmaller cams in the 270° range, subtracting 20° fromadvertised duration will give better results. Theformula for optimum intake runner length (L) is:L = ((EVCD × 0.25 × V × 2) ÷ (rpm × RV)) - ½DWhere:EVCD = Effective Valve Closed DurationRV = Reflective ValueV = Pressure Wave SpeedD = Runner Diameter"
that gives the runner length for helmholtz resonance as a function of RPM and cam duration. it is useful because it contains runner diameters which would be affected by porting, and you can choose which rpm you want to make optimal power at.
so do both, get a port, but no more than about 5ccs or less, and get a sheetmetal intake manifold made. i've already drawn out the plans for mine and the entire build cost shouldn't be any more than 25-30 bucks. or buy a decent one for almost 600 dollars, or get a machine shop to build you one for much less than that.
