One of the hardest parts is that you are dealing with aluminum. When you use a dremel the grind piece gets loaded up real fast with aluminum making it useless. the trick is to get some paraffin wax and coat the grinder in it to keep the aluminum from loading up and you can get much more done.lightsout wrote:what do you use and how do you do the plenium, b/c i wanted to do SOMETHING with mine, if i don't get a custom one made when i've got the cash.
