Porsche 918 Spyder Concept
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
http://a323.yahoofs.com/ymg/au...xZaGL http://a323.yahoofs.com/ymg/au...ZmTfp
Just how fast is this thing? Well, Porsche says the 918 Spyder Concept hits 100 km/h (62 mph) in less than 3.2 seconds, and it blasts to a top speed of 198 mph. Not only that, it laps the Nürburgring in less than 7 minutes 30 seconds, which means it’s even faster than the hallowed Carrera GT.
The 918 Spyder Concept is powered by a high-revving V-8 related to the 3.4-liter in the Porsche RS Spyder racing car. In 918 Spyder form, this mid-mounted engine revs to 9200 rpm and produces more than 500 bhp. Electric motors at the front and rear axles add an additional 218 horsepower to the output. The V-8’s power, and that of the rear electric motor, reaches the Spyder Concept’s rear wheels via a 7-speed PDK gearbox. The drive to the front wheels is pure electric, via a fixed ratio. The liquid-cooled lithium-ion battery pack behind the cockpit can be charged at home, or by brake regeneration.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
The word ridiculous comes to mind. But in a good way. A very overengineered, yet still good... way. And from the tiny pictures you posted, it looks pretty good. A little busy, but good. I kinda like it.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
s0m3th1ngAZ
Car: 96' Miata
2014 Focus ST
Looks like Spyker had a hand in designing it...which means I f***ING LOVE IT.And it's about time a sports car manufacturer makes a serious Electric-Powered AWD system. Lets just hope it doesn't way 4,000 lbs.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I was interested until I got to the "electric motors" part.
Think of how much MORE awesome that thing would be if they left the electric motors and batteries on the ground. These stupid "performance hybrids" are fine from companies like Lexus. But I expected better from Porsche.
Mr1der
ehh...sounds more like KERS than hyrbid.
http://www.itv-f1.com/Feature....43467
it's kinda neat.
jbracy7
my qustion why 9200 rpm redline for a v8 thats kinda crazy.why does it need to rev that high. i think this is porsche's "look we can do green too" car i wonder what the price is going to be 100k+ 200? 300?..... bet the leaf could bet it on electic alone... jk
s0m3th1ngAZ
Car: 96' Miata
2014 Focus ST
IT in NO way resembles KERS...It's a hybrid system with batteries being charged by the engine with what seems like power on demand depending on traction and throttle conditions.If done correctly...it could really blow the competition out of the water. IF it's buggered up...Porsche will have an overweight quick AWD Prius.
The perfect locomotive system for a car would be all four wheels powered individually by electric motors of sufficient power. Supplying those motors with juice could either be full electric via a fuel cell or a small diesel hybrid system. Even steam power would work in this case. Combine this with a suite of sensors, super-fast computing, a good chassis, and light weight and you WILL have the fastest car on the road.
This is assuming all you care about is outright speed and effeciency...which is only one part of the equation when driving a car. Experiencing the whail of a V10 just cannot be matched by whirring motors and rushing wind.
Mr1der
http://www.motorauthority.com/...ncept
it has push to pass teehee
frapjap
'07 Subaru Legacy
That is the sickest looking Porsche in a loooong time!
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
frapjap wrote:That is the sickest looking Porsche in a loooong time!
Well, since the Carrera GT.
Mr1der
or the 2010 Turbo.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
ScorchedNX2K wrote:The perfect locomotive system for a car would be all four wheels powered individually by electric motors of sufficient power. Supplying those motors with juice could either be full electric via a fuel cell or a small diesel hybrid system. Even steam power would work in this case. Combine this with a suite of sensors, super-fast computing, a good chassis, and light weight and you WILL have the fastest car on the road.
That is the system Chevy's Volt, Cadillac's Converj, and Fisker's Karma use. Unfortunately, GM's system is still "wrong." Rather than running at a specifically tuned RPM at all times, offering a good blend of power and efficiency, the gas engine actually generates electrical power on-demand. Which means even though each wheel has its own electric motor, when you nail the throttle, the gas engine revs up just like it would in a normal car. So where the hell is the benefit? At that point, you might as well just get rid of the electric motors altogether.The right way to do it, like you said, is to use a turbodiesel powerplant. Design it to run at <1000rpm constantly. You use the batteries as a power buffer. The engine is always recharging the battery, except under heavy acceleration, during which time the battery capacity takes up duties of delivering "extra" power. You never increase engine RPM because then efficiency starts to drop. You simply take advantage of mixed driving and battery as a combined effort. Battery gets drained (beyond engine charge capacity) during acceleration but gets recharged (beyond power drain from motors) during steady cruise.This design doesn't look good on EPA papers, though, because they will never operate as a ZEV. And everyone knows the EPA is more important than real science. So maybe that's why no one is doing a correct electric-drive hybrid-electric car. No PZEV cert means less tax breaks. I love it when politics get in the way of science.
C-Kwik
jbracy7 wrote:my qustion why 9200 rpm redline for a v8 thats kinda crazy.why does it need to rev that high.
Because the that's the only way aside from adding boost to get 500 HP from a 3.4L gasoline motor.
jbracy7
0rowing the gears in that thing must be like...i have no f-ing idea ive never had a car that revs that dawm high
C-Kwik
jbracy7 wrote:0rowing the gears in that thing must be like...i have no f-ing idea ive never had a car that revs that dawm high
Its not really anything that different. Gear spacing will be such that it will feel pretty much like anyother car with a similar amount of power.
jbracy7
yeah i guess just sounds high a** hell just seams like a waste to me
