Por15 or Rust bullet in Engine Bay?
Az24tsx
Hello everyone i have a quick question for ya'll which would be better suited to use in the engine bay? I just bought a shell a couple days ago and thought i might as well paint the bay before i put a motor in. One other question how do you guys pr what do u guys use to degrease the motor? Im using the Gunk Gel degreaser which seems to work fine but dont trust it in the areas aound the fuse box.
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
take the fuse box out.
its pretty easy yo
i used purple power to degrease mine and i just used a sandible primer and then engine enamel paint
Az24tsx
Does the fuse box come completely out? i just got the box split in two but its not going anywhere?
Az24tsx
Anyone got any input? This is my bros account trying to suprise him with a clean bay before he gets back from CA. Also does the fusebox come completely out?
hbpignosePA
90 Volvo 240 (sold)
which one?
just undo all the push pin platic things and remove the harness from the bay.
place it on the drivers side next to the wheel
easy!
Az24tsx
The one in the engine bay and i'll have a look at it
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
just make sure you mask the car well, overspray sucks
bllabong89
Car: 1995 s14
If I was you, I would do the following:
If you are pulling the wiring harnesses out to do a tuck and so then pull all of the wires out while you don't have a motor and you have less to worry about when degreasing. Once the wiring is out, spray the s*** out of it with degreaser and hit it with a power washer. Most degreasers say to let it dig into the grime for about 10-15 mins then rinse. If there is nothing in the bay, I would just soak it, let it sit for 10-15 mins, and if its really dirty, hit it again and after another 10-15 spray it out.
If you are leaving the wires in the bay, you don't have to remove them to degrease everything. All you need to do is buy some saran wrap from the grocery store and cover all of the wires. Wrap the fuse box and anything else with wires going in it really well just to insure no degreaser gets in. Once tht is done, follow along with the same degreasing method.
Once everything is clean and dry, go over it all to make sure no grime is left over. If there is anything left, scrub it with either a scotch brite pad or a brush and wash with soapy water(basically common sense to clean the left over grime).
I like the POR-15 but thats just me. If you go to their site, www.por15.com, you can get everything you need. They have cleaner called marine clean and metal ready. You spray the marine clean on and follow the directions exactly. Once that is done and dried, you spray the metal ready. After the metal ready is done and dried, your ready for the paint. You can brush the paint on or spray it. I have brushed it on and it has great leveling so you wont really se the brush strokes after it settles and dries.
Note: I believe you can lay the por-15 right on top of the paint as long as you use the metal ready and marine clean but you should check with the directions first. You may need to hit everything with a red scotch brite pad(available at home depot, walmart, autozone, etc.) to scuff the paint so the new stuff has something to ahere to. If that is the case, you SHOULD scuff it before you use the marine clean and metal ready so there is now left over paint dust waiting to make your new bay dirty...hope this helps
