POR 15 and 6 hours later
Ubel Feuer
Car: 2003 Nissan Pathfinder
So I got tired of rust being on the undercarriage, and I did something about it. Behold, the shiny. Still have some touching up to do.
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
wow! impressive! i was planning on doing the same soon but didnt have time. What was your paint process?
Ubel Feuer
Well I did this on my back under my car, as I don't have a lift. If you can find/rent one for the day that would be best.
I power-washed the undercarriage two days before I painted and then didn't drive it, the surface needs to be really clean. I then scraped off and large chunks of rust, leave anything that was not loose.
You need to be covered head to toe, this stuff is impossible to get off you once it dries. I basically just started from the rear and slid forward, covering everything that seemed to be rusting. I left most of the engine block uncovered as it is made of something that doesn't seem to rust. I did paint most of the exhaust pipes, but left the muffler unpainted - I was told not to paint sections that are subject to extreme heat.
I just used a regular paint brush.
Modified by Ubel Feuer at 7:54 PM 6/4/2009
krott5333
Car: 99 pathfinder se
what size paint can did you need? what about using high temp engine or grille paint on the exhaust?
Ubel Feuer
I used about 3/4 of a quart of it, it's 45 dollars a quart.
Any suggestions on he high-temp paint?
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Ubel Feuer wrote:I left most of the engine block uncovered as it is made of something that doesn't seem to rust.
Aluminum
Ubel Feuer
Part 2: Touch-ups
Modified by Ubel Feuer at 8:38 PM 6/8/2009
