Cjmartz2k »
https://forums.nicoclub.com/cjmartz2k-u65761.html
Sun May 27, 2007 2:20 am
I'm around the middle of your range with mine, but it's a lpretty laggy for only 400'ish whp. I'm going TO4R as soon as I can track one down. That's on a stock motor. Your fine with 450-500hp atf on a stock motor with a good tune. You'll need:
TurboManifoldWastegate (depending on the turbine)Standalone ECU (Power FC, V-Pro, etc)injectorsFuel Pump Fuel Pressure RegulatorZ32 MAFClutchSomeone to install/tune
Yeah, if you get used parts where applicaple, you could do it for around 2-3k, but new, 3-5k.
Takiie!
