C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Sep 18, 2006 6:33 am
There are only two things I am aware of that can help with the wastegate opening before hitting full boost. Use a vacuum source from the manifold rather than the compressor exit or in any of the plumbing before the manifold. This will do two things. The wastegate will see true manifold pressure since you won't be having to compensate for a pressure drop. However, it will subject the boost pressure to a slight spike as it ramps up to peak boost. It won't actually increase the wastegate's response, but since it's further away from the compressor, the compressor will be spooling up more before the wastegate realizes you are at full boost.
The second way and better way if you have the money, is to use an electronic boost controller. Preferably of the dual solenoid kind. These are the quickest responding and generally keeps any spiking to a minimum. Most electronic controllers will spike a small amount, as it blocks the wastegate signal until full boost or very near full boost is reached. Some fuzzy logic controllers try to anticipate, but many have not had good experiences with trying to use these. I've only heard of a few cases where everything works as it should. they generally have more success with these in single turbo applications.
Personally, I would just hook up the signal to the manifold and call it a day. Just don't tune on the bleeding edge of reaching detonation or maxing out the fuel system and you'll probably be fine.
