popping sounds in exhaust?
NissanSupraGTR
Car: 1990 240sx SE hatchback
ima make this quick: i hear popping sounds when im in 1st/2nd gear at low rpms...usually happens when i pull into a parking lot in 1st and reduce speed (w/o braking). My cars specs are in my sig, is there anything that causes this?
180fan
Car: 89 fastback
have you removed the aiv yet? if not, it could be with that. the reeds, when open can cause popping through the exhaust.
NissanSupraGTR
aiv? whats that???
180fan
Car: 89 fastback
look at the black box behind the air intake box.
hugesack
Car: 89 240sx
This should be normal. Mismatched exhaust, and a 3" catback on a N/A motor will cause it. You need more back pressure.
NissanSupraGTR
will the silencer help w/ backpressure or just dull the sound out a little?
Sleeksil80
Car: 89 Hatch with S13 front end, koki lights, full cusco suspension. GC8 RHD STI in progress
the silencer will help a little, but the KA doesnt really have the air flow for a 3" exhaust.
though who am i to say anything, i had a Apexi GT spec on my old S13 before i put in my SR. though it would cause the EGR valve to malfunction over like 70mph....
POS_S13
Car: thizzlamics
check for an exhaust leak, might be a bad exhaust flange gasket or exhaust manifold gasket
nightkid86
Car: 97 S14 SE
It's just pressure pops caused by less backpressure than stock. Don't worry about it.
demin
Car: 1990 240sx
NissanSupraGTR wrote:ima make this quick: i hear popping sounds when im in 1st/2nd gear at low rpms...usually happens when i pull into a parking lot in 1st and reduce speed (w/o braking). My cars specs are in my sig, is there anything that causes this?
i have a 3' exaust and ive been running with it for over a year, it happens. you could use the silencer but its not gunna help it much. what you could do is get a different muffler with a lower input diameter and use an adapter this will help some more also. but yeah you really dont need to worry about it.
