tollboothwilley »
https://forums.nicoclub.com/tollboothwilley-u74535.html
Fri Oct 24, 2008 5:15 pm
Three possible sounds coming from front end, I've found and fixed....
The popping sound was the nut on my compression rod that I hadn't torqued down tight enough and it wiggled loose. Its stuck on there good now, and no more popping.
If you are getting a clanking sound when you go over bumps its most likely your strut mounts. It could also be the end links for the sways, which is much more common if you have swapped out to aftermarket.
