popping sound by the brake pedal
benchthug
Car: 2007 Versa SL HB
i just bought back my V to the dealer to get it fixed i dont know if some one else is having this problem...
Problem: When making a hard turn you will her a pop by the brake pedals and you can also feel the pop...
the dealer still have my V for 2 days now and they cannot trace where the problem is but they noticed the hard popping sound...
CodeRed
Car: 2008 Nissan Versa S MT
i had a problem with my brake pedal but it wasent when turning it was when ever i pressed it it made a sqeeky noise they calimed it defective and replaced the whole unit
benchthug
its not the brake pedals its by the brake pedals on the left of the brake pedal to be precise where you rest you left foot on...
CodeRed
benchthug wrote:its not the brake pedals its by the brake pedals on the left of the brake pedal to be precise where you rest you left foot on...
if you are turning real hard i could see that you could be bottoming out your suspension, but that only happens to me if i pull into a gas station going a little too fast
benchthug
the tech just called me and said that the lower arm might be the problem... the car is pretty new and it has a lot of space for the suspension to bottom out even on a hard tight turn...
benchthug
wow i havent gotten my V back yet... they said tomorrow the new parts will come in but the funny thing is that they dont know where the popping sound is comming from... so they will replace the whole suspension if that dont work i dont know hopefully they will give me a new V hahaha... once they find out about this sound ill post it here so just incase someone will have the same problem as me...
motoguy128
Car: 2007 Nissan Versa S - 6 Speed
My car makes this "popping" when I am making a sharp right turn on a declined ramp exiting a parking lot onto a level road. the suspension is articulated to the extremes on the corners. I suspect the load on the steering is very heavy. I'm not sure where the clunk comes from but its in synch with the suspenson moving.
I think a component in the steering system has some slack and it pops as it is loaded.
A second thought might be that the sound is created by something on the strut. THe porblem only occurs for me when the front suspension is loaded doan and compressed.
I also wonder is it's comming form the CV joints. Could the half shafts be incorrectly sized or misaligned?
Like yur dealer, I'm just guessing at this point. I'm not concerned because there are no other symptoms or problems as a result of thsi noise such as wheel alignment, tracking unevenly, looseness in hte steering, any other noises.
shreqboi909
Car: '98 ej8 R.I.P 07 nissan versa/tiida
i have a similiar problem, my V makes a poppin noise when i go over sumthin, a speed bumb or a dip, a bit fast or wen i step on da brakes...i took it in and it was the transmission mount, they tightend it and it stopd for a couple of days and now its back!
benchthug
well i just got my Versa back yesterday they pin pointed the problem to the spacer on the suspension... nissan is now aware of this problem :P thanks to me hahaha jk... yeah the problem is brought up to the nissan folks so if you bring in your versa to the dealer they will replace the spacer and re tighten some loose ends on your versa... im saving up for a new suspension package from tien... hopefully it will be a better ride...
skoobahead
Car: Powder 1.8SL CVT
Can you tell us what spacer it was? (part #, nomenclature) Perhaps the info is on your invoice. This information sure could help us if we have to bring our cars to the dealer
Thanks
benchthug
yes ill do that on monday because the parts that they ordered will come in on monday... :P 3 more days :P but it seems that they fixed the popping sound because i dont hear it but they are they experts... stay tune ill give you guys some more info in 3 days...
benchthug
the part is in and tomorrow they will install it... after that i will post the part number for future reference...
