Popping or clicking from front left.
GreenQ45a
Car: 2012 Altima 3.5 SR CVT - Dark Slate w\Black Leather Sport\Tech\Premium
2010 Pathfinder 4.0 SE Auto - Red w\Grey Cloth Towing Pkg\Tech 1
About the car
1994 Q45a120,000 Milots of new parts.
No new work on suspension..
I just notice a clicking or popping sound coming from the front right wheel.it clicks when you take off or back up... and only for a few seconds..
At work can't write that much ..let me know if more info is needed.
DAEDALUS
Car: 1990 Infiniti Q45
It clicks once per tire revolution, or because the car is rocking? I would suspect brakes or upper link.
GreenQ45a
Its when the car seems to be rocking.
It is not constant it only seems to happen while backing up or taking off
DAEDALUS
Try rocking the car up and down while parked. Have someone sit inside and listen if necessary.
GreenQ45a
Thanks Ill try it 1st thing when I wake up tomorrow and post the results...
You are so helpful Daedalus.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I would also ask about the shim kits the last time the front pads were replaced. May be unrealted, but maybe not.
Aussie Q45a
Car: '89 JDM Q45a, Skyline GTR, '95 Fairlane. MB Winnebago
Hey GreenCheck for a small stone stuck in the tyre tread or maybe it could be a nail stuck in your tyre. Pull the wheel off and have a real good look.
GreenQ45a
While car was parked and off I rocked it FWD and BKWD and could not hear it.
I was thinking brakes.Does the Q45 have U-joint issues?
How do you check the Uppers?
It only pops or clicks while the car is changing from a stopped position to a FWD or BKWD position.
It seems to pop more while backing up.and only for a foot.
Like 1 pop or click while going from stop to FWD.and like 4 while backing up..
Modified by GreenQ45a at 10:57 PM 7/28/2005
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I am thinking links big time with that description.
Let us know when you changed them last. I seem to be on a 30K schedule on both of my G50.
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
can be trans mount it happened to me
slickster1013
It might be your CV axel, does it happen when you take turns sometimes? i'd check that.
GreenQ45a
Front Right brake caliper was not as tight as it should have been.
DAEDALUS and MAXNIX were correct.
I replaced the Rotors and pad and noticed that the FR caliper was slightly loose (Not good)
Now the poping is gone!
Now that thats gone I can hear a single "Click" or "POP" in rear while starting off from a stop.
U-Joints or CV's or brakes again?
jamesmost
is it a creak or a click?
GreenQ45a
A click.
