gordonliu »
https://forums.nicoclub.com/gordonliu-u37714.html
Mon Nov 13, 2006 2:28 pm
yes another popping while steering question.
tc rods - cuscotie rods (inner and outer)- splend links - pdm whiteline type adjustablesway bar - whitelinenismo braceshocks/strusts - christmas trees (kyb agx/tein springs)
ok, so my car makes a noticable popping noise often when i turn right. the noise will sometimes occur when i am returning the steering wheel from a right turn, but it rarely happens when i turn left. i have inspected my suspension and there isnt any obvious problem. i have checked the whiteline endlink brackets and they are not broken. the end links are aligned so that they are practically vertical when the car sits on the ground. i have the tc rods set so that they are equal lengths (i did this because the instructions did not specify a particular length to use as a basis for later adjustments). i also did this for the end links, they are both set at equal lengths.
so i couldnt have worn tc rods (as mine are cusco no rubber)no worn tie rods (solid spl style)and no worn end links (once again solid, spherical bearings)
anyone have any ideas?
