popping noise on left driver side suspension
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
logicmobile
Car: infiniti g35 sedan
hello everyone, i have this problem ask before but never got it fixed yet, and now it got worse i can hear it everytime turning the wheels and sometimes running slow and little suspension play will do it, i dont know if it is ball joint or something..anyone has same issue??? i was reading some topic and they claiming that was the " compression rod" how it look like anyway and where is that located? i have 03 sedan base model
afastsbc
Car: 2003 Infiniti G35 Sedan 1989 Pontiac Formula 350 2007 GMC Envoy Denali
Is it on the passenger side by chance?
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
Did you replace the 'I' in your Infiniti with a 'y'? Anyway, compression rods, if original, are probably bad. They have been redesigned and its a good Idea to replace them, since they will affect your ride, and your alignment. Its a curved metal rod, aluminum in rwd G's and black steel in AWD models, from the knuckle to the front brace. look behind the front wheel, beneath the car.
logicmobile
hehehe sorry...its supposed to be I not Y, anyway its driver side front and , if i would like to change it i have to change out both right? thanx for inputs
"O" G
Car: 2005 Infiniti G35 Coupe
I have an 05 coupe I ordered a bushing for the drivers side compression rod yesterday. That should take care of the popping noise, but I also have a creaking noise coming from the upper steering column. Do you have any idea of what that might be?
logicmobile
creaking noise , i have that too, not too sure but wait for the bushing you got after that, well see, hopefully just same bushing that gives both problem..goodluck
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
How much was the bushing? I want to replace mine when I put on my wheels... Is it a hard job to do?
logicmobile
its machine pressed we cant just do it by our own, well you can take off your compression rod and have the shop do the machine compression for you..around 50+ ...what other people opinion said was the compression rod we had right now was a bad design , they re-design it i guess around 05 models, but new cost 370+ each...well for me i leave it like that until its needs to be really to swap out with new one, i hope the price of new compression rod on that time is low already,,,lol good luck
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
