popping noise in frontend
vglenn1
Car: 2005 altima 3.5l
I just put a lowering 1.3 lowering kit on my 2005 altima 3.5l and now i have a popping noise in the frontend. I took it to a nissan dealer and they told me i stressed out the firewall sub frame bracket. They also told me if i replaced it that it might not solve my problem. Has anybody else had this same problem or no had to solve the noise.
xekushnr
Car: '90 Nissan 240SX Hatch
When do you hear the noise? Under acceleration, braking, turning...please be specific.
vglenn1
I hear it every time i hit a bump and thats the only time i hear it.
driftingmy240sx
Car: 1996 Nissan 240sx rb25det
i doubt that is the actual problem. when does the popping noise occur?
MaximA32
driftingmy240sx wrote: when does the popping noise occur?
vglenn1 wrote:I hear it every time i hit a bump and thats the only time i hear it.
He answered your question already.
In response to your question glenn, I would check to make sure that you tightened everything down when you installed the new parts as it sounds like a loose part. I would especially check the upper mounting nuts (the ones in the engine bay) and the sway bar links.
vglenn1
it happens everytime i hit a bump.
MaximA32
Did you read my post.
driftingmy240sx
make sure the spring is seated in he perches correctly. double check all your nuts and bolts for tightness. its common for me to put struts on these altimas at work for a "knocking noise" you may have a bad strut or two, and the lowering springs just made the noise more noticible.
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
After a nut and bolt drive the car and apply slight brake pressure.See if it changes when braking slightly.
vglenn1
If it is the struts. Witch brand of strut should i put on with the lowering spring.
vglenn1
yes i read your post. Thank you
