Postby
Arlo »
https://forums.nicoclub.com/arlo-u208855.htmlSun Jun 26, 2016 1:27 pm
Hello all,
Yesterday on i_95 my coolant return line blew. I pulled over as soon as i noticed the high temp gauge but i'm guessing I was too late. Had it towed home, fixed the hose, started to add coolant and these i heard these strange popping noises.
Postby
EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.htmlSun Jun 26, 2016 9:44 pm
I was going to guess that the pump was cavitating, but that is usually a more consistent sound. On the large industrial pumps I work with, cavitation sounds like you're pumping gravel.
Other guesses:
-Bad bearings on the fan or the pulleys.
-Are your belts still in good shape - good alignment, good pulleys, no cuts or frays on the belts?
Can you pinpoint where the noise is coming from - stethoscope or good solid rod prodding around the engine bay?
Postby
EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.htmlSun Jun 26, 2016 10:14 pm
What part of the coolant system specifically?
And that sort of makes sense, when you remove the cap you significantly drop the pressure in the system and then the coolant will boil at a lower temp/boil easier. From where I'm seated it doesn't sound like boiling sounds, would you describe it as such from your perspective?
