Winona »
https://forums.nicoclub.com/winona-u28153.html
Mon Jan 02, 2006 12:23 pm
so i can try and race the car, when i hit around 4-5k its starts to cut and and make a popping sound and jerks its set at stock psi but it still rises to 9psi when this happens, i have the sr turbo but also have the sr maf and the maf reads 4.23-4.5 volts when this happens. i was reading a post from awhile ago and dee said that it could be a auto ecu. im not 100% sure on transmission cause i fried my old one and got a new one, but with the old ecu it did the same thing jsut at higher rpms and that was a maunaul for sure. i cant remember the number on the new one right off hand. i was wondering could it be a boost cut? seeing i do have my boost controller set to stock boost and its rising to 9psi could it trying to cut it back at the higher rpms, but also when i set the boost to 10psi i guess it does the same. my fuel isnt running lean either. any ideas?
