poping sound in front
scott240sx
Car: 97 240sx
i have been having trouble trying to find a poping sound coming from the front of my car. i have replaced the shocks, upper mounts, tierod ends, tension rods and there is no play in the wheel if i try moving it around while on a lift
onosqv
Car: '92 240sx Vert
You need to be more specific. When does this happen? Can you reproduce it by doing something while your car is stopped/moving/etc?
For example: car pops when putting into reverse, or car pops when slowing down starting at about 15mph, or while car is parked lean on the front fender and let go and it pops or squeaks, or happens only when turning.
Can you determine if it's a left or right side? Does it sound like metal on metal? Did you check your other bushings i.e. lower control arm bushing? When you replaced the upper mount, did you also buy a new mount gasket?
Did you torque everything down to spec?
Other than the popping, is there any affect on your car (i.e. vibration at a certain speed, pulls a certain way, something suspension related)? etc?
When did this start happening? What was the last thing you did on the car before it started happening?
Details man, details.
navysnail
check to make sure the spring isnt turning on the perch.
Nismo_Freak
Car: 89 Nissan 240SX
Check lower control arm to tension rod nut torque.
scott240sx
Car: 97 240sx
i can feel i most at low speeds and when the wheel is turned. it feels like the passenger side. i happens when i stop or i hear it at low speeds when going over bumps. this sound started when all the parts where stock. the front control arm bushings look fine and when i have had it on lift i used a pry bar to check for play but there did not seem to be any. also the car pulls to the right even though i just had an alignment.
NoStickDrift
Car: 1989 240sx
Check the strut tower itself. If its bad or the bearing is bad it will make a popping sound when turning and such.
Thoughtful_One
Car: 1998 Nissan 240SX SE
2000 Honda Insight
I had the same problem. I went to the mechanic and when he lifted and let go of the right front, the popping noise would form. I could see and was told that the strut itself is seized and needs replacement.
scott240sx
Car: 97 240sx
the strut has been replace and the sound is still there. i guess the only thing left could be my control arm bushing or could my rack and pinion be going bad.
koUki20
Car: 89' Nissan 240sx
yup my guess is the rack and pinion.
scott240sx
Car: 97 240sx
how much would it cost to replace to replace the rack and pinion
One_Love
Car: 1995 nissan 240sx
i had a popping noise from my front left side also, turned out it was my sway bar pin or link as they call it in autozone.
Rican_Nick
i had the same issue on a previous car. it was actually my spring binding causing the pop. do u have lowerings prings on it? and u say u already replaced the upper pearch?
scott240sx
Car: 97 240sx
i recently put coilover and pillow upper mounts. i was hoping that would stop the poping but it didn't.
HKSpeed
i have a pop/clunk sound up front when i turn at low speeds. i was told it could be worn ball joints.
scott240sx
Car: 97 240sx
the ball joints have been replaced also with not luck
One_Love
im serious check your sway bar pins, one might be too far seperated or stretched out
koUki20
try checking or replacing your rack and pinion.
ricebike
2002 Quest
2005 Altima
semirb86 wrote:i had a popping noise from my front left side also, turned out it was my sway bar pin or link as they call it in autozone.
+1
I had the same exact thing. Hit a pothole in the mean streets of the Bronx... then popping noise was heard when making a right turn & was localized to my passenger side "swaybar endlink."
Heck, I'm still waiting on 240Kid's offer for that thing since I think he has upgraded his swaybars...I temp repaired it by putting a washer over the nut.
scott240sx
Car: 97 240sx
where can i get some sway bar endlinks? i don't want to go back with stock.
One_Love
Napa sells them
ALLUR.SX
Car: 95 240sx
hey guys a have the same problem , low speeds. bumps turns. and clunck clunck clunck clunck. and the sound doesnt change if you get a litlle speed. the same clunck clunck cluck.... in the driver side. i thoth it was the 18s but no........ will guess shocks.....
scott240sx
Car: 97 240sx
i feel stupid!! i just replaced my tension rods with new kazama t-rods and the popping sound stopped. i noticed when i was taking off the rods the side that the noise was coming from was not torqued down and they were easy to take off so hopefully that was the problem. also the rsponse of the new tension rods is great but i can feel the cracks in the road a little bit more now
dfw240_EE
Car: 1992 240SX
I have the exact same pop, and I know it is coming from the right side. I know this because whenever I go over a speed bump with the left over smooth pavement and the right over the bump it makes the pop, but if I do it left on bump, right off it does not make the pop. I suspect my tie rods personally, but I will also check the tension rods and sway bar link. I think I will go get some film in the camera and take photos of as much of the suspension as I can.
I went under the car today and gave the tie rods a wiggle, the left felt solid, but I could feel abit of play in the right. Plus on the left the rubber bushing around the end link (where tie rod meets wheel) was shredded.
scott240sx
Car: 97 240sx
dfw240_ee if you are going to replace your tie rod end and are not going to upgrade go with nissan tie rod end because the price is the same as after market and the quality is better.
as for my popping sound it is definatly gone. yaaaaaaaaaaaaayyyyyyyyyyyy. i have been trying for so long to find the noise. thanks for the advice everyone
dfw240_EE
Car: 1992 240SX
scott240sx wrote:dfw240_ee if you are going to replace your tie rod end and are not going to upgrade go with nissan tie rod end because the price is the same as after market and the quality is better.
My research has found that Autozone Tie Rods are $50 and Tein rods are about $80. I think the extra $30 would be well spent.
