pop ups to silvia
SoCal-s130
I have honestly searched everwhere and I just converted to silvia front and I can't figure out how to wire my existing wires to the sil lights. I know the driving light plugs in through the existing harness from the flip ups. On the triple projectors is the middle or outside light the driving light? Because when I plug mine in and turn them on they dont work but when I flip my high beams on it does. So what I am wondering is how do I get my fogs, and corner lights to work as well?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Fog lights aren't a direct plug in. The center light is your high beam and the outside light is your low beam.
If your lights aren't working, pull the bulb out and test the plug that the ballast plugs into to make sure it's getting power. A test light is the way to do that. If you have power to the ballast, you probably have a blown bulb. You can just run down to your local car parts store and pick up a new one.
The corner light should have two plugs. One is for the turn signal and should be wired to the front turn signal. The other plug will be your marker light. It's a direct plug in from the old marker light. I did have to extend the wires to my marker lights as the wires were a hair short and made it hard to install the light after I plugged them in.
To get your fog lights to work, we have a few articles on 240sxtech (click the drop down link in the top bar) as well as my how to. My how to is pretty in depth and if you're new to wiring, could be a tough task to handle.
